maisiestar avatar image
maisiestar asked
Multiplus 3000 120amp Lithium/Generator settings
I'm a complete novice, so please forgive me if I'm wording this wrong. We live off grid, and have a Multiplus 3000 120amp inverter and recently upgraded out batteries to, 2 x 200amp lithium batteries, which are in parallel. Both inverter and batteries have been working brilliantly. We also have a 2000 watt generator, which use to work brilliant with the inverter when we had agm batteries. I recently tried hooking the generator up since changing to lithium and the inverter doesn't like it at all now. Please could someone advise if there is a special setting I need to change on the Multiplus 3000 inverter. The settings have been changed on our mppt charge controller for lithium but nothing on the inverter. Please advise. Thanks in advance
multiplus in parallel
Trevor Bird avatar image
Trevor Bird answered ·
Hello @MaisieStar ...Perhaps you could elaborate on "doesn't like it all now". Does that mean the charger doesnt work or does it mean the Multiplus will not accept the generator input at all?
Thanks
ponzoa avatar image
ponzoa answered ·
You'll also need to adjust your charge setting and battery voltages to the new batteries to avoid damaging them. This is done via the VE Direct software with a laptop or via VRM. Ensure you have the correct settings or you risk damaging your new batteries.
Every comparable battery type and brand in Lithium have different settings which can be found on the Victron website.
ludo avatar image
ludo answered ·
Set the grid current limit to 8a when running from the generator and all should be well
