svtti123 avatar image
svtti123 asked
Multiplus syncing question.
I have a 2000 watt multiplus in a cargo van with 400 amp hour lipo4 batteries and same set up in a RV. is it possible to run the necessary com cables power cables even though they are not located directly next to each other and have them sync up and act as 1 bigger unit? When boondocking
multiplus in parallel
Alexandra avatar image
Alexandra answered ·
@Svtti123 Paralleling Victron units to double up power is usually for static installation as the wiring balance is quite important to get right. So is it possible? - yes. Is it practical? not so much. There will be more headaches than rewards especially if you are not experienced in these systems.
It will require reprogramming every time you dock and un-dock if they are to separate. So they can be stand alone again.
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
