slapperia avatar image
slapperia asked
Cerbo - NMEA - Raymarine MDF
I have several Raymarine Axiom+ MDF screens in my boat. The Cerbo is connected via Ethernet and NMEA to the system. There is a problem with the NMEA 2k network when the Cerbo is connected. If I try recording NMEA messages via the MDF, the MDF crashes after approximately 1 minute. The same happens if the engine gateway is sending data. (Powered up). All the other devices on the NMEA network does not cause this behaviour, meaning that if the Cerbo and/or engine gateway is off, the system is stable and MDF does not crash during NMEA messages logging/recording.
Raymarine thinks this has something to do with the Cerbo. The Cerbo is running firmware 2.9 large.
Any advice is much appreciated.
cerbo gxNMEA 2000 - N2Kraymarine
