gerald-d avatar image
gerald-d asked
Multiplus charger setting for DIY built lithium battery
I have a MultiPlus 12 | 1600 | 70 230V. Until this morning it worked happily with lead acid batteries 3X 105 Ah in series. Today I converted to a lithium battery consisting of 4X 3.2V LiPo4 cells 280 Ah.
The battery specs are:
I do have a BMS that trips at 14.8 V (3.7 V per cell)
Right now the Multiplus is set as follows:
How should I adjust those numbers to try and hold a 90% state of charge?. Should I be using a smart shunt or something else?
Thank you
Multiplus-IILithium Batterycharger
