stephenjdrew66 avatar image
stephenjdrew66 asked
ac coupling easysolar
I read that the easysolar system incorporates a multiplus. As multiplus allows ac coupling does this mean easysolar also allows ac coupling?
EasySolar All-in-OneAC PV Coupling
porcini avatar image
porcini answered ·
Yes, all of them do, even some Phoenix. For an offgrid installation you need the PV inverter support assistant and the PV Inverter has to be connected at the output of the multi. For ongrid ESS would be the best choice and it can be connected both. When the Inverter is used at the output it must not be bigger than the kVA value of the multi.
raymond-nicolas avatar image
raymond-nicolas answered ·
Hi
Interesting note (I follow this topic)
I just order an easysolar 24/3000 and I hope, exceptionally to increase its capacity in power during 30minutes, up to 6000 or 7000W with AC coupling.
With Fronius inverter, It's very simple.
I wondered the question of feasibility because on the victron spaces where the subject is addressed it is always with multiplus or quatro inverter.
RN
Hi @RayMonD NICOLAS
In the easysolar it's the same hardware as a Multiplus, so yes, it has the same functions.
Please read about the 1:1 rule for AC coupled PV:
https://www.victronenergy.com/live/ac_coupling:start
