lexexpeditiontruck avatar image
lexexpeditiontruck asked
Cerbo GX water and temprature sensors
Hello!
I want to install water level and temperature sensors in a black, grey and clean water tank but I am getting stuck on which one works and which one doesn't.
1). Do the Wema gevers s5 (0-190 ohm) work with the Cerbo GX? If they work how reliable are they in a black water tank? https://www.nauticgear.nl/bootaccessoires/bootonderdelen/motorinstrumenten/wema-gevers/wema-gevers-voor-water-en-brandstoftanks-s5 or are there better water level sensors for a black water tank?
2). What kind of temprature sensor works with the Cerbo GX which perhaps can be mounted in the tank or on the tanks? I see the LM335 works but how can I make this one water tight and mount it in the tank and wire it up with the cerbo?
cerbo gxTemperature Sensorsensor
