darren-1 avatar image
darren-1 asked
Single 12v Panel capable of Charging 24v battery array MPPT 75
Hi
I have had a supplier incorrectly supply solar panels that are 12v and its impossible to return them as we remote.
Specs: 140w
Open circuit: 22.68V
Optimal operation: 18.90v
Short Circuit: 8.00A
Optimal Operation: 7.41A
Will a single panel charge 24v 24ah (2x 12v 24ah "gels" in series)
Using a Victron MPPT 75 | 15 (NO BT)
MPPT Controllersbattery chargingcharge current limitsolar sizingcharge controller compatibility
wkirby avatar image
wkirby answered ·
How many of these 12V solar panels do you have?
If you have more than one then you can connect the panels in series also which will double their Voltage to the controller.
If you only have one panel then it will not work.
darren-1 avatar image darren-1 commented ·
1 panel
kevgermany avatar image kevgermany ♦♦ darren-1 commented ·
To add. MPPT will only start charging when panel voltage is more than 5V above battery. So if your system is at 26V, you need more than 31V from the panels.
