99sport avatar image
99sport asked
Fusing of low-power Victron components (VE.Bus BMS & BMV712)
Does anyone know what fuse to use in the power line for the VE.Bus BMS? The instructions show it in the diagram (attached) but I cannot find any mention of the type of fuse to use. (For comparison, the Color Control GCGX states in the manual to use a 1amp slow-blow fuse).
Also, what fuse should be used in the power line to the shunt shipped with the BMV712?
Thanks
BMV Battery MonitorBMSinstallation
kai avatar image
kai answered ·
I don't think its particularly critical as far as the BMS is concerned.
Since the manual said nothing, go with the standard approach of sizing the fuse according to the wire gauge.
Justin Cook - Bay Marine Supply USA avatar image
Justin Cook - Bay Marine Supply USA answered ·
I'm late to this question, but @99sport, the BMV shunt PCB power supply fuse is a 100mA quick-blow; the BMS fuse is the 1A slow-blow.
wkirby avatar image wkirby ♦♦ commented ·
If your BMV has a 100mA fuse in it then you should swap it for a 1A fuse.
The 100mA fuse presents too much Voltage drop and will cause the Voltage readings to be inaccurate.
Newer BMV's will ship with a 1A fuse.
Justin Cook - Bay Marine Supply USA avatar image Justin Cook - Bay Marine Supply USA ♦ wkirby ♦♦ commented ·
Oh man, good to know! Thanks @WKirby; I know a number of our BMVs have had the 100mA fuses in them, but I haven't checked a recent version. Will take under advisement!
