bgardiner avatar image
bgardiner asked
Second SmartShunt incorrectly shows discharging only on VRM dashboard
screenshot-20220831-085750-chrome.jpgHi, we are offgrid using a Victron EasySolar 3000 plus two Multiplus 3000 Inverters. We have one smart shunt for the battery (48 traction) and a second for our wind turbine. The system works perfectly - except that the wind turbine shunt (configured as DC Energy Meter with Wind Turbine selected) shows discharging on the victron dashboard (see attached photo). When I connect to the shunt directly through VictronConnect - either online or bluetooth - then it shows charging correctly. I'm guessing this is a bug in the Victron Dashboard - but just wanted to run it past the community first and see if there's a workaround. It's not a huge problem - just annoying! :)
Thanks, Ben.
SmartShunt
