simoly avatar image
simoly asked
Multiplus I is restarting when cerbo is connected
Hello, I have Multiplus I 12/3000 (year 2022, but not Multi II). Work well, but in moment Multi is connected via VE.Bus to Cerbo, Multi is ca after 5 second switched off and restarted. It repeat still. Used Victron utp cable and used ve.bus connector on cerbo (not Ethernet). Where shoud be problem? Any switch settings is necessary?
Thanks
MultiPlus Quattro Inverter Chargercerbo gx
@Simoly
Is it definitely plugged into the VEBus port?
simoly avatar image
simoly answered ·
Yes, Ethernet is one (with LEDs) , Ve.Bus are two ports. 100% connected to Ve.bus on Cerbo
Kevin Windrem avatar image
Kevin Windrem answered ·
And NO termination on the VE.bus?
simoly avatar image simoly commented ·
No terminator on Ve.Bus. I tested it with next cerbo, problem persist, when connected Cerbo to Multi (VE.bus, RJ45 UTP uncrossed) is after ca 5 second switched off, restarted, and switched off again...it keeps repeating.
No termination on ve.bus, of course.
