basstscho avatar image
basstscho asked
EM24 Grid meter shows as AC-Load
Hi together,
I'm completely new to Victron-World and setup my first installation: Grid -> EM24 -> MP II (x3) on AC-IN, parallel the load. So a parallel installation of the MultiPlus II to the "grid" (no AC-Out is used).
Unfortunately it shows the pages a little bit strange: Grid is not available. The EM24 is configured as Grid meter. Instead the AC load shows the values of the EM 24. But the AC-Load should be: Grid + Inverter. But it looks like, that the control works fine (200W from Grid as minimum adjusted).
Is there a way to change this?
Thank you and best,
Johannes
ESSEnergy Metergrid parallel
