Pierre-Marie Baty avatar image
Pierre-Marie Baty asked
How to extend Multiplus-II GX 48/5000 ?
Hello
I have a ESS system that runs well, centered around a MPII-GX 48/5000. The integrated GX feature is very nice. Now I would like to increase its inverting capacity to 10-12 kVA.
Do you think it would be best if I swap it with a MPII 10000 (with an external Cerbo GX to restore monitoring capability) or add a "slave" device (if possible) to my existing MPII-GX and if so what sort of hardware would you advise for that ?
If you already set up such systems, I'd appreciate to hear your retrospective feedback.
Thanks all in advance for your replies,
Multiplus-IIVenus GX - VGXmultiplus in parallel
Alexandra avatar image
Alexandra answered ·
@Pierre-Marie Baty
For a DIY setup, swap to a bigger device and uograde the battery bank as well.
The other alternative is to split your DB up and run a totally separate system for the other loads independent.of the first system.
Parellel systems can be complicated to troubleshoot and get right. (Actually even as a person who installs). And you never quite get twice the power anyway. So a 10 to 12 load with 2 5s will be just out of reach.
For 12 kva load inverting you need 15kva of inverter.
Pierre-Marie Baty avatar image Pierre-Marie Baty commented ·
Hi Alexandra and thank you for your reply. Yes this is a DIY setup.
What device(s) are you thinking about more precisely when you advise me to swap my MPII-GX to a bigger device ?
Pierre-Marie Baty avatar image Pierre-Marie Baty Pierre-Marie Baty commented ·
I see that for 15 kVA my only choice is the Quattro. I guess this answers the question...
Alexandra avatar image Alexandra ♦ Pierre-Marie Baty commented ·
Yeah. Definitely need the power house there.
