ranger-rick avatar image
ranger-rick asked
SmartShunt settings for a 24 volt battery bank
What SmartShunt settings do I input for my 24v 200Ah LiFePO4 battery when programming/setting up the SmartShunt? Thank you :)
SmartShunt
mike4nl avatar image
mike4nl answered ·
example-1.jpg@Ranger Rick
Here an example of the settings.
- Set your battery Ampere Hours
- Set the Charged Voltage four your LiFePo4 pack
- Set the Discharge Floor in percent.
That's the start. Then ask or better read the manual so that you underestand which is meaned for which entry in the settings.
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fcdn.shopify.com%2Fs%2Ffiles%2F1%2F1836%2F4403%2Ft%2F19%2Fassets%2Fpf-cafd9edc--Image1_1000x.jpg%3Fv%3D1619144842&f=1&nofb=1
ranger-rick answered ·
Thank you Mike, but those are settings for a 12Volt battery bank. I need them for a 24-volt battery bank (with two SOK 24v batteries connected in parallel). SOK provides little info.
