ronski avatar image
ronski asked
Parrallel Multiplus II 48/5000 - maximum transfer load
As we can't use the Multiplus II 48/10000 due to no G99 certification we may need to use two Multiplus II 48/5000 in parallel.
The transfer switch is rated at 50A, does that mean that two in parallel can transfer 100A?
I know all cables AC & DC need to be the same length.
PS. I have a separate question relating to using the Quattro 48/10000 instead.
multiplus in parallel
daniel-feist avatar image
daniel-feist answered ·
2 x 50A would be 100A in parallel, yes. What I'm not clear on though, and I asked in a separate thread, is how to interpret the 50A maximum. i.e. is it continuous/peak etc?
See: https://community.victronenergy.com/questions/151332/multiplus-ii-transfer-switch-overload-characterist.html
