Salim Naufal avatar image
Salim Naufal asked
MPPT Charging Voltages in Networked Mode Set with bluetooth or remotely?
I have 4 MPPTs, 3 Multiplus 2 a BMV 712 and a Cerbo gx, all networked.
In order to change the battery charging voltages, is there a centralized was of doing that where the values are set in one location and those values are propagated to all the devices?
So far, I have been using the VRM Configurator to set the voltages on each of the Multiplusses and the bluetooth to set them on each of the MPPTs
cerbo gxbattery chargingMPPT SmartSolarsmart solar charging behaviour
wkirby avatar image
wkirby answered ·
MPPTs in networked mode will be following the charging parameters set in the MultiPlus, so the MultiPlus is the central place to set the values.
Best to set the same values in the MPPTs also in case the networking is unavailable for any reason, like if the CerboGX is rebooting during a firmware update for example.
