jeff-lawrence avatar image
jeff-lawrence asked
MPPT will not charge when CerboGX has no power but will charge if I...
I found that I depleted my batteries and everything turned off. I have a MPPT 100/50 connected to a CerboGX. The MPPT just flashes "Bulk" and nothing.
..... If I disconnect the MPPT from the CerboGX, the MPPT"Bulk" becomes solid and then charges my the batteries ....
The annoyance is real.
Why does it do this
MPPT Controllersbattery chargingcerbo gxsmart mppt
Define flash?
I am looking at my 100-50 after dark and it is blinking the blue bulk led on for .25 second, every 4 seconds.
What sort of battery/bms?
Mike Dorsett avatar image
Mike Dorsett answered ·
It does this because the Ve bus is all pulled low. This happens when you have a Mk2 or Mk3 plugged into the VE bus too. Unfortunately there is no solution to this, except to power the GX device from the battery - with a lower drop out voltage than the inverter.
