How does the high temperature affect the DC side of the Phoenix inverter?
@karam abu-alhija
- Depending on the Tempratur inside the Phoenix he can switch off with temperatur error if that one is to high. (Internal Control)
- On normal use the fan must be running to cool it down.
- Important is that you mounted the Phoenix model so as described in the manual. It is about the air flow that must checked
BTW: which Phonix model is it?
Hi Mike,
Thanks for your response, To be more clear, my question is: How does increased temperature affect the power input (DC side) of the Phoenix Inverter VE? Is there a direct ratio?
29 People are following this question.
