alex376 avatar image
alex376 asked
EM24 RS485 über Modbus TCP Server
Hello, I have the following problem: I do not get my second EM24 with RS485 connection displayed in my Cerbo GX.
The first EM24 for the grid I have connected via USB on Modbus port 1, which works fine.
The second EM24 I have connected via RS485 Modbus TCP Server (Waveshare RS485 to ETH (B)). And configured on Modbus port 2. I just don't get it displayed in the Cerbo. The server seems to work because I can access the meter with the USC tool from Carlo Gavazzi via Modbus TCP and read the data.
I have activated Modbus in the Cerbo under the item Services-Modbus.
I get the meter neither with the Modbus scanner nor with manual input displayed. The Cerbo and the Modbus server are in the same IP network and have different adresses .
And I do not know now no more further. Who can help or give advice?
Thanks in advance.
Modbus TCPem24
mike4nl avatar image
mike4nl answered ·
@Alex376
You wrote:
- second EM24 I have connected via RS485 Modbus
- Waveshare RS485 to ETH (B).
I have heared about some issues with the Waveshare but can't say it is yours.
Have you activated the end resistor for the RS485 on the EM24 and the Waveshare adapter?
- This could be an issues. A wrong terminated BUS can give a lot of trouble.
So far my first thougths.
matzik avatar image
matzik answered ·
Hello Alex,
you wrote "The server seems to work because I can access the meter with the USC tool from Carlo Gavazzi via Modbus TCP and read the data."
I'm trying the same with a CG EM111 and a Waveshare RS485 to ETH (B). But I'm not lucky to access the EM111 from the USC tool.
How did you configure the Waveshare RS485 to ETH (B) ?
The Waveshare RS485 to ETH (B) and the GC EM111 are connected and the blue act-LED is flashing.
Thank you!
Matthias
Modbus TCP Basics
Energy Meter Manual EM24 RS485
