mcarse avatar image
mcarse asked
Cerbo GX and VE.Smart Networking
I have the following installed:
- BMV-712
- Blue Smart IP22 12/30 Charger
- SmartSolar 100/30
These are all currently communicating using VE Smart Networking.
I would like to add a Cerbo GX and eventually a GX Tank Monitor.
I would like the Cerbo GX for remote remote monitoring and data logging purposes (read only). Can this be done without interfering with the VE.Smart Networking?
Reason being, I would like the BlueSmart IP22 to still be able to obtain charge data from the BMV-712. I have considered replacing the Blue Smart Charger with a Phoenix IP43 Charger 12/30 however don't appear to be able to source them in Canada.
Thanks for any help.
Matt
cerbo gxBMV Battery MonitorVE.Smart Network
kevgermany avatar image
kevgermany answered ·
Smart networking is specifically for installations that don't have a GX device. You'll only be able to monitor devices that have a cable interface such as VE.direct.
mcarse avatar image
mcarse answered ·
Thank you, I understand I will only be able to monitor the devices with a VE.Direct Port. Will connecting the Cerbo for remote monitoring, cause the Smart Network to stop functioning correctly? I just want to add the remote monitoring to my existing setup.
I would like to leave the Smart Network enabled to allow the BlueSmart charger to benefit from the data. I would leave DVCC disabled on the Cerbo.
