Glen Carter avatar image
Glen Carter asked
MultiPlus II 12/3000/120-50, 4 Smart Solar 100/30 MPPT, CerboGX and 800A LiFePO
I am building a RV system with:
  • 4-440W LG NeON R solar panels
  • 4- SmartSolar 100/30 MPPT into Lynx Power In w/fuses
  • 8-100A LiFePO batteries into 2-Lynx Power In w/fuses
  • Smart Shunt 500A
  • MultiPlus II 12/3000/120-50
  • CerboGX/Touch 50
  • Orion-Tr Smart 12/12-30A Non-isolated DC-DC charger
My main question is regarding connections to the CerboGX. The Smart Shunt and 4-SmartSolar = 5 VE.Direct. Does it make any difference which units are connected via USB-VE.Direct? The Solar panels are on slides and 2 are exposed at all times, the other 2, only when opened.
Is it best to put the 2 panels on slides on the USB to VE.Direct?
Multiplus-IIcerbo gxMPPT SmartSolarSmartShunt
wkirby avatar image
wkirby answered ·
It really doesn't matter which ones use the USB to VE.Direct connections, the functionality is just the same between the USB connected and straight cable connected MPPTs.
