johnb80 avatar image
johnb80 asked
What is the best BMS to use with MultiPlus-II 48/5000/70-50 230V GX
I about to expand my home solar PV / Battery system by adding a completely independent unit. 16 x 280ah LifeP04 EVE cells connected to MultiPlus-II 48/5000/70-50 230V GX. I need to get a BMS, what would you guys / gals recommend for this ideally I'd like something that will just plug & play or am I hoping for too much?
BMS
Louis van der Walt avatar image
Louis van der Walt answered ·
If you want to get a DIY BMS to work, then I suggest one that is supported by my serialbattery driver.
Although I never suggest the Daly, any of the others should work fine.
https://community.victronenergy.com/questions/76159/victron-venusos-driver-for-serial-connected-bms-av.html
There are a few other BMS that is also supported. Just get the best BMS for the money you have.
johnb80 avatar image johnb80 commented ·
It sounds a tad complicated, whats involved harware and software please.
@johnb80
If you're asking for a Victron recommendation then the answer is none. Victron BMSes are specifically for Victron lithium batteries.
Thanks for the info
That seems such a shame, given that pretty much all batteries are LifeP04 why do they not supply it? it only monitor the voltages in the normal way and switch on and off as required.
baxter avatar image
baxter answered ·
REC, Batrium, Seplos, JKBMS
johanndo avatar image
johanndo answered ·
Look at the REC, good integration.
