emilijanenko avatar image
emilijanenko asked
Victron PWM LCD duo PV voltage problem
Hello. I've connected 2 new 95Ah AGM batteries and 12V 100W panel to Victron PWM LCD duo regulator (20A). When I connect everything in correct sequence PV voltage shows around 13,2 V and batteries are being charged at the same voltage (1,5 - 2A). When I messure voltage directly on + and - cable from panel I get reading around 20V. Regulator program iz set to B01 (AGM). I have even tried another regulator and same thing happend. Is this ok? Sky is celar and sun is high. Batteries where new and almost full. Thank you very much.
victron communityBlueSolar PWM
Mike Dorsett avatar image
Mike Dorsett answered ·
This sounds normal, with the PWM activity, panel voltage will rise as the battery charge gets to full.
emilijanenko answered ·
Ok, thank you. Other setup with classic lead acid batteries shows around 20V PV and 14,4V battery 1 and battery 2. I'll monitor the controller in upcoming days to check if anything changes.
