This should be in the manual but I would be a max of about 20amps. then it will trip out, make sure you have a fuse in the battery positive cable as per the manual.
Link to the Manual https://www.victronenergy.com/upload/documents/Manual-BlueSolar-Charger-12V-24V-20A-EN_FR.pdf
the below is from the manual.
(The load current is 1.25 times of rated current for 60 seconds, or the load current is 1.5 times of rated current for 5 seconds)
4 People are following this question.
