erni avatar image
erni asked
Kann die Bosch bsec Library nicht kompilieren
root@raspberrypi2:/opt/bsec_bme680-homie# ./make.sh
Patching...
Already applied.
Compiling...
/usr/lib/gcc/arm-ve-linux-gnueabi/9.3.0/../../../../arm-ve-linux-gnueabi/bin/ld: cannot find -lm
/usr/lib/gcc/arm-ve-linux-gnueabi/9.3.0/../../../../arm-ve-linux-gnueabi/bin/ld: cannot find -lrt
/usr/lib/gcc/arm-ve-linux-gnueabi/9.3.0/../../../../arm-ve-linux-gnueabi/bin/ld: cannot find -lc
collect2: error: ld returned 1 exit status
Venus OSmodifications
johanndo avatar image
johanndo answered ·
Install all developer tools for the tool chain with opkg first.
erni avatar image
erni answered ·
Would you please give the detailed Packes as Iam new using opkg?
Thank you.
erni avatar image erni commented ·
I did search the internet but the most topic I found are about this is with debian and his packetmanger apt.
I search opkg list and didn't find the keywords you wrote like
Thank you
erni avatar image
erni answered ·
Ich nutze das large image in der Version
root@raspberrypi2:/usr/local/sbin# cat /opt/victronenergy/version
v2.90~14
Victron Energy
20220616130540
Den Sensor und die Werte kann ich mit einem python Skript auslesen.
#!/usr/bin/python3
import board
from busio import I2C
import adafruit_bme680
# Create library object using our Bus I2C port
i2c = I2C(board.SCL, board.SDA)
bme680 = adafruit_bme680.Adafruit_BME680_I2C(i2c, debug=False)
# change this to match the location's pressure (hPa) at sea level
#bme680.sea_level_pressure = 1013.25
# You will usually have to add an offset to account for the temperature of
# the sensor. This is usually around 5 degrees but varies by use. Use a
# separate temperature sensor to calibrate this one.
#temperature_offset = -5
temperature_offset = 0
print("Temperature: %0.1f C" % (bme680.temperature + temperature_offset))
print("Gas: %d ohm" % bme680.gas)
print("Humidity: %0.1f %%" % bme680.relative_humidity)
print("Pressure: %0.3f hPa" % bme680.pressure)
print("Altitude = %0.2f meters" % bme680.altitude)
# Minimal example configuration with common sensors
#i2c:
#bme680_bsec:
#sensor:
# - platform: bme680_bsec
# temperature:
# name: "BME680 Temperature"
# pressure:
# name: "BME680 Pressure"
# humidity:
# name: "BME680 Humidity"
# iaq:
# name: "BME680 IAQ"
# co2_equivalent:
# name: "BME680 CO2 Equivalent"
# breath_voc_equivalent:
# name: "BME680 Breath VOC Equivalent"
#text_sensor:
# iaq_accuracy:
# name: "BME680 IAQ Accuracy"
Die Ausgabe würde ich gerne ins Venusos übernehmen.
es heißt das large image die Build tools enthält.
@Netrange
Oder was meinst du mit der Frage?
Danke sehr.
