What will happen if the VE bus Smart Dongle is connected to a parallel configuration of 2x MultiPlus Compact 24/2000/50 FW 497?
Will Victron Connect connect to both Multi's?
Yes when you initially are making the 3 phase or Parellel config. Then you can set settings to all three at once.
It does not work like ve config.
There is a demo video on this blog post.
28 People are following this question.
