kennybuntinx avatar image
kennybuntinx asked
"configured for VE.bus BMS" checkbox on Multplus II and REC BMS
Hi ,
I updated my three faze system today to the latest firmware on my Multiplus II 48 volt 5000 inverter/Charger .
When logging in with VE configure 3 to restore my config , I noticed this new "configured for VE.bus BMS" checkbox .
Can anyone explain what this does and if I need to enable this with my REC - BMS setup ?
Try to understand and any help is appreciated ...
Kenny
Multiplus-IIbattery chargingLithium Battery
Alexandra avatar image
Alexandra answered ·
@KennyBuntinx
The VE Bus BMS is Victrons BMS that plugs into the ve bus on the inverters directly. So has nothing to do with the rec bms as far as I know since it connects to the cerbo via can bus.
https://www.victronenergy.com/battery-management-systems/ve-bus-bms
kennybuntinx answered ·
Thank you for that answer. For me this was totally unclear in the documentation.
johanndo avatar image
johanndo answered ·
Do you use 2-wire bms macro with the opto coupler from REC?
The activation of the macro to stop charge / discharge may indicate a BMS connection as Ve.Bus BMS.
@JohannDo
That setup would use the 2 signal bms assistant.
The ve bus bms bms supprt assistant for victron batteries has been depreciated. The feature @KennyBuntinx is seeing I assume is the option being used now instead.
johanndo avatar image johanndo Alexandra ♦ commented ·
I use the 2-wire bms Assistant as well, the Ve.Bus device sets the parametes accordingly to BMS TYPE=1. and the readings on the inputs.
I have a REC ABMS without CAN integration into Venus.
johanndo answered ·
I use a REC ABMS without CAN BUS or other integration into the Venus OS, just the 2-wire BMS Assistant and signals to stop charge and discharge by the optocoupler outputs, works as expected.
The Quattro internally treats it as Type 1 BMS
