bitcrusher avatar image
bitcrusher asked
Use cerbo relay to control buck boost with d+ signal
Is it possible to forward the D+ signal through the cerbo relay to control the input pin (purple wire) of a buckboost?
I like to use the genset on/off switch in the cerbo to switch off the buckboost manually if there is enough soc while driving.
Thanks!
cerbo gxRelay
wkirby avatar image
wkirby answered ·
Use the Cerbo relay contacts to connect the purple wire (D+) to Battery + to enable the pin.
Apply your settings in TS config to suit your needs. Also use the Cerbo NC or NO contacts to make the logic on/off work for you.
