mquetel avatar image
mquetel asked
Victron BMV Temperature in (F) but MPPT has temp in (C) in iOS app.
I have a BMV-712 that is sharing battery voltage and battery temperature with a Smart Solar MPPT 75/15 via VE.Smart networking. I've recently noticed that the temperature as displayed in the VictronConnect iOS app is different units depending on the device I choose in the app's device list. For example, when the BMV is selected, the temp units are set to Fahrenheit and that is what I see on the status page. If I select the MPPT device, the temperature is displayed in Celsius on the status page. I don't see a way to configure units on the MPPT side and since it is a value shared from the BMV it probably shouldn't be necessary to do that anyway. I don't recall this issue in the past, not sure if it happened because of an app update or firmware update. Can someone assist?
MPPT ControllersBMV Battery MonitorVictronConnect
Chris avatar image
Chris answered ·
Mine has always done this. I would like it fixed, but in the mean time, I use it to brush up on my C to F conversions.
Mike Mitchell avatar image
Mike Mitchell answered ·
I can confirm this behavior. It's been like that for awhile so I don't believe it's tied to an app or firmware version. I hope it gets fixed; I wouldn't go so far as to say it chaps my hide... but it is annoying.
JohnC avatar image
JohnC answered ·
You can change the BMV but not the mppt. Matthijs has replied to a similar Q here: https://community.victronenergy.com/questions/4423/android-app-and-celsius-vs-farenheit.html So there is hope..
havoc5150 avatar image
havoc5150 answered ·
I found it .... Its under Device list and on the top left hand side you will see the hamburger symbol. Then under settings. Boom your good to go.
