marktkauf avatar image
marktkauf asked
Loads wrong with AC PV inverter
KHi,
I have extended my existing PV (SolarEdge SE8k) system with a three phase Multiplus 3000-48 and 6 pylontech 2000 setup with a EM24 grid meter and Cerbo GX. After going live I see the following:
Two things puzzling me:
  1. AC Loads should be around 400W instead of 2504 (3488W production - 3086W to the grid)
  2. All my loads and the SE8k is connected to AC Out 1. so they loads should show up under „critical loads“ I suppose.
Going through the settings of remote console I couldn’t solve that.
I would appreciate any hints where to start.
Thanks a lot!
Multiplus-IIcerbo gxAC PV Coupling
Hi @marktkauf,
You will need to adjust the inverter position in the GX device menu.
In the GX device settings menu, go to PV Inverters and set Inv: Position to AC Output.
You can watch me program one here in the AC PV online training - GX device settings for AC PV
esa69 avatar image esa69 commented ·
Thx mate, I could solve my problem, 2 inverters at AC IN but one was seen AC load. The connection in the Cerbo GX was L1 but in reality it was L3, So I changed it in the GX from L1 to L3 and problem solved,
marktkauf answered ·
Hi @Guy Stewart (Victron Community Manager) ,
thank you so much for your help. With that I could get the loads to the correct position.
Is there a hint for my first question also:
I have PV production of 6777 (which is correct an seen on the inverter) and a flow to the grid of -6069 (as seen on the EM24). I would expect the (calculated) AC loads to be the difference: 6777-6069=708. (Please see picture)
I am sure I have wrong assumptions and would appreciate your help.
Thanks,
Markus
There appears to be an issue with your battery connection, it is displaying at 37V.
I would investigate what is wrong there, starting from the beginning - https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
jdippel avatar image
jdippel answered ·
I had the same problem. I solved it by connecting the inverter to phase 1. Previously it was connected to phase 3.
Greetings
