gary bastin avatar image
gary bastin asked
Lithium battery on old 19 chipset multi
So I have 2 x 5kw 24v multis with the 19 chipset. Latest firmware 209 with assistants..
My lead acid batteries are coming to end of life and I want to buy new lithium batteries. Such as master battery or pylontech
I see there is an assistant for lithium... so does than mean I can install any lithium such as above or even BYD without issues with bms ?
I had been looking at 24v lithium with built in bms but choice is very limited.
MultiPlus Quattro Inverter ChargerLithium Battery
Battery Compatibility
