Is it ok to use the 1A trickle charge output of the Multiplus to charge a lead acid starter battery when the main batteries house batteries are Lifepo4?
The House Lithium batteries will be charged from either mains through the Multiplus, MPPT or DC-DC from the alternator/Starter battery.
The starter battery will be charged by the alternator, but I’d like to have the ability to trickle charge it from the Multiplus if possible.
Not sure if the 1A trickle charge will be a problem if the Multiplus is configured for lithiums through.
I’m interested to know if it is ok to have both lithiums and lead acid charged from the same Multiplus due to their different charging voltages etc, not whether it will technically do it.
I know it will do it.
My truck starter battery reads 12.6v, 36 hours after being fully charged, no load.
My Lifepo4 battery still reads 13.25v @ 87% Soc.
That is a whole lot of voltage differential that could allow energy to flow from a partially discharged Li battery, to a fully charged LA battery.
NOTE, there is some discussion as to whether the multi "switch" disables the trickle charge function.
Proceed with caution, and give feedback upon conclusion.
The trickle charger is taken off the main DC feed to the Multiplus. The Multiplus contains a current limiting circuit and a diode so it will always lift your starter battery to within 0.4 to 0.6V lower than your house battery because of the voltage drop. When full the battery will limit the current lower than 1A. If your house is at 13.25V, the trickle charge will keep the starter at circa 12.65 to 12.85V so OK for the starter battery long term, but there will be a small current draw from the house.
@pwfarnell just further to the question , I have 2x multiplus 3000 with 2 AGM starter batteries that I would like to trickle charge from the multiplus 4A, I have lithium house bank, is the situation the same?
Yes. One thing to remember is that depending on the lithium system, the trickle charger may not be disconnected on low battery voltage.
there seems to be a draw from the starter batteries ,I am thinking the Orion non isolated dc dc charger is causing this.
I have port and stbd battery switches that I guess I could isolate the starter batteries so essentially they are off.
I just want the batteries charged so they are available when needed!
56 People are following this question.
How can Multiplus 1 be used to increase charge power in ESS system with Multiplus 2 and GX
MultiPlus-II: charge separate starter battery?
Camper Van Schematic - please critique
Are my MultiPlus II VE Config charger settings correct for 4 x Omnipower 200Ah batteries?
firmware compatibility three phase system MultiGrid-II and MultiPlus-II
