cargol66 avatar image
cargol66 asked
48/5000 Quattro inverter temperature sensor with BMV712 shunt wiring
Hi Everybody,
I have an MPPT 150/70 to charge a 220 Ah 48V battery bank and also a Quattro 48/5000 inverter with a temperature sensor. This sensor is actually wired on negative battery terminal.
Now I'm adding a BMV712 500A 50mV shunt on the negative battery terminal.
Question: where temperature sensor should be wired now ?
- always on the negative battery terminal ?
- or on the "Load and Charger" shunt terminal ?
If the sensor is "electrically isolated" it can be wired on the battery terminal, if it is not, it must be wired on the "load and chanrger shunt terminal to get the same potential than before (without the shunt.)
Regards.
MultiPlus Quattro Inverter ChargerBMV Battery MonitorTemperature Sensor
snoobler avatar image
snoobler answered ·
Wire to the battery terminal. If you don't, you won't be measuring the temperature of the battery.
