i-connect avatar image
i-connect asked
Mppt 100/30 not visible in connect app
Hi, Just installed my new system, mppt100/30 connected to a 12v lifepo battery.
I started with connecting the battery, bulk led flashes slowly, mppt is not discovered in the victron connect app.
Connected the solar array and mppt is charging, still not discovered in app.
Tried removing all power (both battery and solar array) and reconnected again, same issue.
Tried another phone, same issue.
I also have a smart shunt and that one is visible and can be connected to.
Any tips or is this a hw issue in the (brand new) mppt?
Thx, jeroen
VictronConnect
seb71 avatar image
seb71 answered ·
BluesSolar MPPT? It does not have Bluetooth.
SmartSolar MPPT has Bluetooth.
Also, don't connect the PV array to the MPPT until you made the correct settings.
i-connect answered ·
Damn, that's stupid, it is indeed a bluesolar, so I did not look into that well enough, not sure where that went wrong in my head probably "blue" in the name just made me assume it would have bluetooth....
Why do they even sell with and without bt, price difference is only around 20 eur...
Anyways, thx for letting me know, saves a lot of trying and searching
So I will need to get a ve-direct to usb cable to make the settings...
Thx!
Besides the VE.Direct-USB cable/interface, there is also the VE.Direct Bluetooth dongle option. Choose one depending on the device you want to connect to it (PC via that cable or phone via Bluetooth).
It can also be configured via a GX device, but that is expensive and not feasible for small systems.
Try to return the BlueSolar and get a SmartSolar instead.
Or probably setting the rotary switch to 7 (for lifepo) is enough configuration, so no need for the ve direct cable....
In theory, that should work, but it's risky to trust only that, without any confirmation. For instance the battery voltage should be auto detected, but what if something goes wrong? You can't see the actual settings. And also the default settings might not be optimal.
Also no way to update the firmware.
