andywb avatar image
andywb asked
SmartShunt showing the wrong percentage
I have a pair of 165AH AGM batteries (Victron BA412151080), wired in parallel for a total of 330AH at 12v.
Recently the state of charge was showing 57% remaining, despite 209Ah consumed - i.e. it was showing that only 43% had been consumed, when in fact 63% had been used.
How can this be, please? Do I have a faulty SmartShunt?
A couple of days later, and without charging the battery, the SmartShunt started showing 100%. This was without intervention from myself and despite the fact that the battery was even further discharged - you can see this from the voltage level, which I did not notice at the time.
I now realise that I allowed the voltage to get low enough that the batteries may have been damage, which is extremely annoying considering I was relying on the SmartShunt to monitor them. I never allowed them this low when I was using my boat's simple voltmeter!
Have I done something wrong please, or is this a common fault of SmartShunts?
SmartShunt
While @Alexandra has given you the corrective action, I'd like to answer your specific questions:
You failed to properly configure the SmartShunt.
No. There is no evidence of a fault with your smart shunt.
Yes. Again, you failed to properly configure your SmartShunt.
Alexandra avatar image
Alexandra answered ·
@AndyWB
You need to disable starts synchronised.
And set your charged voltage in the app.
@AndyWB
Just in case you get a surprise, these suggestions are good, but SOC will not show until the charged conditions are first met. After that, as long as there's a reasonably frequent full charge the monitoring will be accurate.
You can also set a low voltage alarm in the smart shunt. Look at the alarms page of the smart shunt settings.
trevor-bird avatar image
trevor-bird answered ·
@AndyWB … you may benefit from watching this video. As previously mentioned you do need to set “charged voltage”.
https://youtu.be/0HG4GiH9su8
