Hello
I would like to know if it's possible to collect data directly from a BlueSolar 75|15 MPPT by using a cable and without using the VictronConnect App.
Thanks !
Hello
Thanks !
Yes, you can use the serial interface of the Ve.Direct port. The documentation of the Ve.Direct HEX protocol and the Ve.Direct TEXT protocol are on the Victron Website
https://www.victronenergy.com/support-and-downloads/technical-information
You need a Ve.Direct to USB cable or a RS232 TTL (5V) to USB adapter, the Victron cable is galvanically isolated and a better choice.
74 People are following this question.
