t-portal avatar image
t-portal asked
Autotransformer wiring diagram 120v & 230v shorepower
I need to make the autotransformer auto-detect the shore power is 120v or 230v so the transformer nows if it should kick in .
I installed:
2x Multiplus-|| 24/5000
4x LifPo 25,6v 200Ah
1x buck a Boost 50A
1x MPPT 250/70
1x Lynx Smart BMS
2x Lynx distributor
However , is there something fully automatic that you can use 230v shorepower ( bypass the autotransformer) and 120v shorepower ( use the autotransfomer) or do you guys now a manual solution.
I cant see installations using both grid voltages.
Thanks
Remy
Multiplus-IIAutotransformer
