clevergreen avatar image
clevergreen asked
Ecoflow Delta Pro overloading Phoenix 1200 above 300w
HI there,
I've got a Phoenix 1200 hooked up to my CCP on a 2020 transit. I had hopes of using it to charge my Ecoflow Delta Pro via the 120v plug. I tried running the set up the other day and I couldn't get Phoenix to stop overloading unless I set the Delta Pro to a charge rate of 300w (it's adjustable from 100w-1800w I believe). Am I missing something about why this wouldn't work at a higher wattage?
Any help would be appreciated. Thanks! JT
Phoenix Inverter
