Merle.Peter avatar image
Merle.Peter asked
Enable SOC on VE Config3 or not
I'm a bit confused what the Settings "Enable SOC " on VEConfig 3 does if you have a BMV and Venus GX settings set to "Syncronize VE Bus SOC with Battery set to ON " Is it recommended to still have the VEConfig settings set to enable monitor or not ? No assistants running , Multiplus in Backup UPS Mode?
MultiPlus Quattro Inverter ChargerBMV Battery MonitorVenus GX - VGX
You may not notice any operational difference in your situation.
The recommended setting for the most functionality is Enable SOC in VEConfig, and synchronise VE Bus SOC on the GX.
