Looking to make something like @Rob Duthie's stetson but with VE.Bus and more CAN busses.. Reading around the VE.Bus looks like RS485? Can anyone confirm? Rob - are you willing to share your raw files?
Thanks
Thanks
Hmm found this [https://raw.githubusercontent.com/victronenergy/venusgx-hardware/master/VE_BBB_Cape_v0.80_released.pdf] which does look like a RS485, but with a pic operating a couple of extra lines.. and no pic source code..
Hi Yes i can
PDF attached of the schematic, i was designed foe the raspi3B+ boards
But are testing with the raspi4B+ boards.
I only have a basic prototype made up to test before getting the PCB's made. For the VE bus i use just the Mk3 to USB inteface to use it with Victron equyipment. The CanBus can have two but i have only have one at the moment. just tying to keep it on one PCB to fit in the dinrail case i have for it.
Regards
Rob D
NZ
Your only choice for VE.Bus connectivity is to use the MK3 USB interface. I know it's an expensive interface but you only need one in a system.
Remember, this bus is responsible for synchronizing multiple inverter/charger devices in a parallel and/or multi-phase environment. You wouldn't want to step on this low-latency, mission critical communication with a badly timed message. I don't know the details but suspect that much of the protocol is implemented in custom silicon.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
44 People are following this question.
