solarbeginner avatar image
solarbeginner asked
Scalable system with RS 48/6000
I have a RS 48/6000 connected with 1,6kwp Solar panels (4 panels on one string), Cerbo GX and 2xPylontech US2000C 48V batteries. Until I can afford expanding the Pylontech to 5x US2000C and extending the solar panels to 4kwp, I plan to run no higher loads then around 2000W.
I had the idea to secure this with a 10A Fuse between Load and the inverter, in order not to harm the batteries if the load requests more power ...
Is this a useful idea, or do I need to upgrade to 5x US2000C instantly ?
Thanks in advance
inverter rs
kevgermany avatar image
kevgermany answered ·
The output should be fed to a distribution board with proper circuit breakers (rcd etc.). Running the output through a suitable breaker before the board would be better than a fuse which you will possibly be replacing regularly. But check in the manual, there may be a current limiter in the configuration.
solarbeginner avatar image solarbeginner commented ·
Thanks for the quick response. Can I use a site power distributor? I think of something like this:
https://www.amazon.de/ELS-Elektrotechnika-230V-Baustromverteiler-Verteilerk%C3%A4sten/dp/B09WVT4CTG
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
