Any one ever had this error ?
Ve direct to colour gx
Byd bms
All been working fine for over 4 months then this error message nothing in the Manual for inf67
To other moots working ok with byd bms
All firmware up to date
Regards
Mike
Byd bms
Regards
Mike
https://www.victronenergy.com/live/mppt-error-codes
The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charging, as a safety precaution.
Check the connection between the charger and the BMS.
How to reset the charger, to de-couple it from the BMS
When the charger needs to operate in stand-alone mode again, not controlled by a BMS, it needs to be reset:
VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31).
VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, and then reconfigure it.
Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX.
Has anyone seen the error message before ?
Has been running fine on a system form4 months with no issues
Know a err 67 is a connection lost error message
Unplugging the ve direct to usb and substituting to for a known working cable doesn’t solve the issue
But must admit haven’t tried powering the unit down and resetting it from default again
Just a question if any one has seen or had the error before and what solved it
Mine do that when they cant see the BMS (not a BYD system), which seems to echo other answers. A selective reboot and checking of data cable security might resolve your issue.
5 People are following this question.
