matzotom avatar image
matzotom asked
Should a smart shunt show a positive load when the Orion DC/DC charger is charging
I purchased my Sprinter based camper last year as a first-time campervan owner. Overall, I’ve found it to be satisfactory although there have been some areas that could be improved. The battery life when off-grid was fine but the re-charging capabilities seemed poor.
I have fitted a Smart shunt to better understand power usage, an orion DC/DC charger and a MPPT 100/20 solar controller.
When the engine is running, the smart shunt does not show a positive power input, only power being drawn. Is this correct?
Because I am a complete novice, I'm not sure that I have wired the system correctly. For information, the van is fitted with a Sargent EC155 unit. I have fitted the Orion as the Sargents built in DC/DC charger is not compatible with smart alternators.
I have found a wiring schematic and modified it to show exactly how the system is currently wired.
SmartShunt
freighttrain avatar image freighttrain commented ·
Exactly. The shunt cannot measure current that does not flow through it.
klim8skeptic avatar image
klim8skeptic answered ·
Move the negative output from the B2B over to the negative bus.
Move the negative output from the mppt over to the negative bus.
