andriesf avatar image
andriesf asked
Phoenix Smart Inverter 24/5000 alarms
I do have an issue with my recently installed Phoenix Smart Inverter 24/5000. While the battery voltage is above 27 volt the inverter gives very frequently low voltage alarms in the range of 26 to 28 volts and restarts then.
Cabling checked 100mm no lose connections and voltage on the entrance measured with a digital multi meter.
It is connected with a VE bus to a Victron Color control and has also a Inverter control with a switch.
Anyone ideas what can cause these problems.
Regards Andries
CCGX Color ControlPhoenix Inverter
