jarjarbinks avatar image
jarjarbinks asked
Recently charged car battery won't start
Hey All,
Recently purchased a Victron 12v 15A battery charger.
Charged my century battery of 2 years as the car was not used in over 2 months and it charged completely (used recondition option) over 24 hours. Charged 66 AH?
It has been less than a week and the car won't crank, have only started it here and there as I don't currently drive.
Is it possible that the battery is just dead? or could there be something else draining the battery when not in use?
I thought when the battery passes the device test and holds a charge it would work normally or at least hold a car for longer than a few days.
Was able to jumpstart the Car using a Gooloo GP4000.
Car is a Mazda 6 2009.
Would appreciate any comments.
battery chargingAGM Battery
kevgermany avatar image
kevgermany answered ·
If the battery is faulty, it will appear to charge, but will show a quick voltage drop. And it won't maintain much voltage when you try to start. Off charge, what is the battery voltage? And how long since it was charged?
4 comments
jarjarbinks avatar image jarjarbinks commented ·
Don't have s multimeter to check the off charge voltage. Been 5 days since full charge. I wondered if it could be parasitic draw, but that also requires further testing. Or maybe the battery is just dead since it was not used for 2 months.
kevgermany avatar image kevgermany ♦♦ jarjarbinks commented ·
Multimeter is a lot cheaper than a new battery. But I wouldn't keep on with the recondition charges. I'd be tempted to get the battery tested at a battery centre.
jarjarbinks avatar image jarjarbinks kevgermany ♦♦ commented ·
Fair enough, thank you for your help, would any cheap multimeter work for the testing?
Yes, no need to spend a fortune. If you want more versatility, go a little higher and get one with a clamp for current measurements. You'd be surprised how often you use them. Should be able to get a decent one under 30 bucks.
VictronConnect VE.Bus charging manual
