cinergi avatar image
cinergi asked
How to verify "High Current" model Superpack
A friend has two 100Ah High Current superpacks, or so the invoice says. I can't find a way to verify whether he's got the regular ones or the high current ones from a model number / writing-on-the-battery perspective. No documentation or images I've found make this clear. (We don't trust his installer)
I'd like to find out for sure because the's got two in parallel and they're shutting down with 140 amps of load (70 amps each) and the high current model is supposedly rated for 100 amps sustained each (200 total in his configuration). The batteries are diagonally connected in parallel so it shouldn't be a matter of one of them taking more load than the other (no clamp meter to verify yet).
SuperPack
