Peter Polz avatar image
Peter Polz asked
Superpack charge/discharge control?
Good Morning
May anyone can provide me some more infos about Superpack. Actually there is no manual for it.
Especially for me i am interessted in how allow to discharge and charge works in case of only one connection to terminal? Will the mechanism completly block in case of error that customers have to reset something or is there internally an diode mechanism which can handle both direction seperatly controlled with one terminal?
regards Peter
SuperPack
markus avatar image
markus answered ·
Paul B avatar image
Paul B answered ·
I am presuming you are talking about lithium battery packs here
you should install a FULL bms control system, and this will depend on what your requirements are and how you want to go about it
the below link maybe of help. AGAIN I am presuming you are talking about lithium LIPO batteries
Its quite a good article and well worth reading to the end. NOTE this is information only so please look at other areas as well as not everyone has the same opinions in this area.
https://marinehowto.com/lifepo4-batteries-on-boats/
