I’m wanting to order a quick disconnecting connector sized for the battery leads. Don’t see info on size in data sheet or manual
The Multiplus Compact 24/1200 *should* be the same. 16mm2.
https://www.victronenergy.com/upload/documents/Manual-MultiPlus-Compact-800-1200-1600-EN-NL-FR-DE-ES.pdf Section 4.2
Thanks John! I’m guessing they did not include that table in the US manual since the wire sizes don’t easily convert. 16mm2 is about 5 AWG. They make #6 and #4 AWG pins for the Anderson connectors, so will order both and see which fits....
5 People are following this question.
