strommen avatar image
strommen asked
Cerbo GX + 1x Quattro 24/5000 and 3x Phoenix 24/5000
Hello all!
I've just installed the Cerbo GX and connected it with the Quattro 24/5000.
Can I also connect the 3x Phoenix 24/5000 to the same Cerbo? And will it give me information about load, use, etc.?
The Quattro is the only unit connected by UTP-cable. 3x BV-700 are connected by VE.Direct cables.
Brgds,
Marius
MultiPlus Quattro Inverter Chargercerbo gxPhoenix Inverter
wkirby avatar image
wkirby answered ·
A single CerboGX not designed to monitor multiple systems. It's meant to monitor and control a single unit or multiple units configured as a single system in parallel or multiphase.
Separate units or systems are much better off on their own Cerbo GX / Venus GX each then each system can be monitored independently.
strommen avatar image strommen commented ·
OK, thanks! :)
