gbradleyviper avatar image
gbradleyviper asked
MultiPlus inverter & charger. 2000 Watts, 24 Volts DC does not invert but does charge
I have (2) MultiPlus inverter & charger. 2000 Watts, 24 Volts DC, 120 Volts AC, 50 Amp chargers connected in parallel for AC output.
Yesterday I wanted to charge the batteries with the 2 MultiPlus's. I plugged one of the inverters into a GFCI outlet and it turned on the yellow light on the front panel and had a big hum. I disconnected the power source. Now the inverter does not work to output AC electricity. It still charges. Any ideas what happened to it. Any fuses to check?
Thanks,
Guy Bradley
multiple inverters
