Odd avatar image
Odd asked
MPPT smart charger Bluetooth
Hello. I have two smartsolar mppt. Only one showing Bluetooth. Any know how to fix this problem. Look at pictures. Missing enable Bluetooth on a150
Bluetoothsmart solar set-up help
kevgermany avatar image
kevgermany answered ·
Try turning off the one that's working by disconnecting it. What happens then?
From the image it looks as if you have a Bluetooth connection to both. I'm not sure on the software, but it might disable the Bluetooth display if they're bound in a smart network.
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Odd
I assume that you have them connected via VE.Direct as the Bluetooth part is not visible in the Product Info menu. This would then also explain why the Bluetooth on the 150/85 does not seem to work: In these models, the internal bluetooth dongle shares the VE.Direct connection with the external connector and because of that they cannot be used at the same time. When the external VE.Direct is used, the internal bluetooth dongle shuts down.
Kind regards,
Thiemo van Engelen
I've corrected the title to help future searches
